Harder hitting sub for Stealth Box
Old Oct 25, 2005 | 12:19 AM
bubba24's Avatar
I was wondering about getting a stealthbox with the alpine sub also, but how does the alpine sub type r perform in that box. Pretty good hard hitting bass up front? I just don't nessecarily want to give up the t-top space, but if I could use the stealth box and keep that space and atleast use up that useless space in the fender, then cool. If not i would just sacrifice the t-top space and put a box in the middle with 2 12.
Old Oct 26, 2005 | 07:22 PM
megabass's Avatar
I highly recommend getting a dedicated sub amp. Those multi channel amps aren't very efficient for running as sub like a true mono amp is. If you had a 400 watt mono amp, and wired your current sub in parallel to 2ohms, you would be most impressed. jmo.
Old Nov 26, 2005 | 03:52 PM
STA's Avatar
STA
The type r works great in the stealth box. It sounds awesome inside the car, and I love the fact that I did'nt lose my hatch space. Just make sure you match the ohms of the sub to the amp to get the most power to the sub. It's not earth shaking bass like some of my friends systems, but I only run a single 10 which is fine for me .
