Harder hitting sub for Stealth Box
. It has nice SQ but it doesnt hit hard and gets overpowered by my front components. If I went with the same sub but with D2 Ohm it would get 400 watts rms. My question is, would 400 watts make a big difference as far as SPL. I listen to alot of rap music so I like bass. Im not looking for earth shattering bass, but something that can be felt by a car in the other lane. Or is there a better sub out there than the Alpine that works in a stealthbox. I have been looking at the 10w3v2 and Arc 10D2, would these perform better? I would like the 10w6v2 but it doesn't come in a D2 ohm. Thanks in advance.
. It has nice SQ but it doesnt hit hard and gets overpowered by my front components. If I went with the same sub but with D2 Ohm it would get 400 watts rms. My question is, would 400 watts make a big difference as far as SPL. I listen to alot of rap music so I like bass. Im not looking for earth shattering bass, but something that can be felt by a car in the other lane. Or is there a better sub out there than the Alpine that works in a stealthbox. I have been looking at the 10w3v2 and Arc 10D2, would these perform better? I would like the 10w6v2 but it doesn't come in a D2 ohm. Thanks in advance.Could I get even better results if I switched to a 10w3v2 versus the type R given the same power. I have heard good things about JL subs and don't want to kick my self later by not considering it. If anyone has heard the two which is better?
According to mbquart's web site that amp is not 1 ohm stable. http://www.mbquart.com/2003/en_US/pr...&model=RAA4200
It's 100x4 into 4 ohms rms,
200 x 4 into 2 ohms rms, or
100 x 2 into 4 ohms + 400 x 1 into 4 ohms (bridged mode).
With that in mind, using a 4 ohm DVC sub, each coil is 4 ohms. The sub can be wired in parallel which will give 2 ohm load, but the amp is only able to do 200 watts into such a load. The amp cannot be run in bridged mode with a 2 ohm load (resulting in ~1 ohm load at the speaker terminals).
Or the sub can be wired in series which gives 8 ohms, and the resulting power will be ~50 watts. Either way you're underpowering the sub.
What made you get a dvc 4 ohm instead of a 2 ohm to begin with?
If/when you get the 2 ohm dvc sub, you can wire it in series or parallel and still get the same output.
In series, the apparent impedance will be 4 ohms, and your amp can do 400 w x 1 in bridged mode.
If you wire each VC independently, you still get 200 watts into each VC at 2 ohms (not bridged).
Personally, I think I'd go for the series hookup since that will deliver the same signal to both VC's (in terms of phase).. Power across each VC will still be 200 Watts (recall in series circuit, the current is the same through both loads, only the voltage differs - each load has half the total voltage dropped across it (assuming equal loads)).
. As stated above I can't wire the sub in parallel because my amp is not 2 ohm stable in bridged mode. So, my type R is wired in series for a 8 ohm load, and only getting 200 rms I believe in bridged mode. Correct me if i'm wrong, this was my very first system build so i'm just a novice.Sooo...I guess going from 200 to 400 rms with a new D2 ohm sub would make that much of a difference, yes? I know everyone raves about the alpine subs but wouldn't the JL sub be better. ALpine makes good HU but JL specializes in subs. I heard a 10w7 once and it freakin scared me. The specs for the 10w3v2 say it would work in the stealth box. Has anyone listened to both in this type of box? I need some real world comparisons of the two or any other sub out there. Since i'm going to spend the money I want to get the best sub for both SQ and SPL.
If you double the power, you gain 3 dB in volume. If I recall from a different thread, to perceive a doubling of volume you need ~ 6-10 dB gain. So at least 4x the power. Of course, this varies with frequency as well, as we gauge loudness differently at different frequencies.
The Type R is rated up to 200-500w RMS, and i believe 1500 pk watts. Is there no way to turn the gain up on your amp for the sub a little?
Or perhaps fade to the rear (assuming you used rear rca's for the sub amp input)..
GPz is correct with his wiring post above. RUN THE D2 IN SERIES! You want the EXACT same signal sent to each voice coil. Or else they will fight each other, which you do not want.
