replacement speakers for the mosoon???
Old Jul 1, 2005 | 07:30 PM
HioSSilver's Avatar
Default replacement speakers for the mosoon???
Anyone have any recommendations for a upgrade? I want to replace just the speakers because I have a blowed one.thanks
Old Jul 1, 2005 | 07:47 PM
30thanniv's Avatar
I would get the speaker rebuilt. It will be cheaper and easier then to find a replacement with the way that GM screwed up the monsoon system.
It won't be easy to find a person who rebuilds speakers as it is a lost art, but if you ask around I am sure you will find.
Old Jul 1, 2005 | 08:21 PM
chads00ss's Avatar
I blew my front two speakers and had to upgrade to Alpines, sounds good but was alittle bit of tedious work to make it function right. Refer to the sticky at the top of the page under frequently asked questions.
Old Jul 2, 2005 | 07:26 AM
2000 TAWS6's Avatar
You can get replacement Monsoon speakers from link below. I just bought one for the rear panel next to the seat, 4" round and it was $ 17.50.
***NON SPONSOR***
Make sure you put your VIN in when asked as they verify every part versus the VIN.
Just ask Paul (phone or email) for what you need and he will send you link to part.
Great for ALL GM parts.
Old Jul 2, 2005 | 08:18 AM
Luna's Avatar
I had a blown out one in my drivers side door and replaced it with a 6 3/4" Pioneer 4 way sounds much better and basically dropped right in. Definetely recomend something like that
Old Jul 2, 2005 | 11:07 PM
BlkTARebel99's Avatar
I would say either puchase an exact replacement. If you want to upgrade, then, depending on which speaker popped there are a couple of options. The main key is to keeping the ohm load the same to the amp.
Old Jul 3, 2005 | 03:02 AM
SpecialK's Avatar
THe monsoons are nice, but aftermarket is better and if sound is important to you, I suggest getting somthing with a rubber surround, they'll last a LOT longer and sound a LOT better.
Old Jul 8, 2005 | 01:22 PM
Syxx613's Avatar
sorry to bring this thread back to life, but i didnt want to create another thread.... anyways...
i blew my woofer on the drivers side back seat. where can i get a replacement? i went to the dealer and they said it would be 65 bucks to replace. i just need the one replacement woofer, im not looking to upgrade my system right now (no cash) thanks guys!
Old Jul 8, 2005 | 03:11 PM
Kirby's Avatar
$65 sounds about right for a 6.5" midbass speaker. I went to a local audio store and they quoted the same sized JL for $90 each. Here are some speakers that should work with that application and they are free-air which you will need unless you find a way to enclose part of the inside of the panel. http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old Jul 8, 2005 | 03:40 PM
1320_PERFORMANCE's Avatar
this speakers..do they just bolt in w/out any modfications?
Old Jul 8, 2005 | 04:32 PM
shouldaboughttheZ's Avatar
they will bolt in. But you will need to cut the clip from the factory harness to attach the wire to the speaker.
Old Jul 8, 2005 | 04:34 PM
Kirby's Avatar
The only thing you'll have to do is cut off the connector at the end of the wires and plug the wires into the speaker. I'm not sure which wire is + or - on the drivers side but on the passenger side the green wire is +. I can't remember if the drivers side is the same color or not. Just try it out and see what works. It won't hurt anything if they're backwards for a brief second.
Old Jul 13, 2005 | 11:24 PM
brising's Avatar
I was wondering what the OHM's are on the 6 1/2 midbass speaker. I was thinking about replacing the factory ones since they blew. Anyone have a suggestion on what to replace the factory ones with and what OHMS they should be? Thanks
Old Jul 14, 2005 | 03:57 AM
factory subs are 2ohm. Camaro have single voice coils - 2ohm, Trans Am has dual voice coils - 4ohm + 4ohm.
You can pull the factory sub out, and get the part number off of it.
Then go to gmpartsdirect.com and put the number in their search engine. I checked on the trans am sub yesterday and it was like $41 shipped to me.
Old Jul 14, 2005 | 09:27 AM
brising's Avatar
so the factory subs are the speakers directly behind the driver and passengers seat? They are 2 OHM's? I just want to make sure before I order thanks.
Old Jul 14, 2005 | 09:39 AM
GPz1100's Avatar
On some earlier camaros they were in the rear hatch (my friend's 93 has 'em back there). Most later cars they're in the sail panels (between the rear seat and front seat).
