Attaching sub to stealth box
Old Jul 1, 2005 | 09:52 PM
GPz1100's Avatar
Default Attaching sub to stealth box
This might be a very basic question. Since I never installed a sub, I will ask.
To mount the sub to the box (subthump stealth), what size screws do I want to use? The sub is an alpine type R 10".
Do I want to go all the way through the box, or just partly?
Old Jul 1, 2005 | 10:06 PM
firebirdude's Avatar
Not sure what you mean buy "all the way through the box", but the screws should stick out inside the box.....if that's what you mean. No, they shouldn't be through the mounting surface and through the entire opposite side of the box sticking out! lol Use the largest size screws that will fit through the mounting screw holes on the subwoofer. Course threaded is preferred. But make sure the screws don't crack the wood when you screw them in. Pilot holes help a ton.
Old Jul 1, 2005 | 10:11 PM
GPz1100's Avatar
Of course I don't mean for the screw to come out the other side of the box (12" screws??? don't think so ) I was referring to the mounting flange.
I think i'm going to use something called T-nuts. They have several prongs that dig into the mdf. They go in from the back side, then from the front, you use a machine screw to attach.
Old Jul 1, 2005 | 10:31 PM
That'll work fine, but it's a little overkill. Unless you're worried about thieves seeing your "stealth" box.
Old Jul 1, 2005 | 10:41 PM
GPz1100's Avatar
<shrug>.. I just don't want the speaker loosening after a while. What I may just do instead is use the extra sheet metal screws I have left, attach those clips on the backside (speed clips) with contact cement, let 'em set, then use the 1" or 1.25" screws..
Old Jul 2, 2005 | 12:00 AM
Luna's Avatar
They are not going to come loose for a very long time with regular screws, just screw the freakin thing in!
Old Aug 29, 2005 | 01:39 PM
Camaroz's Avatar
Hahaha i just had to do this
Old Aug 29, 2005 | 03:24 PM
00PewterSS's Avatar
Just use wood screws, drywall screws whatever. Predrill the MDF to make it is easier to screw them in. Just screw it into the wood though, don't mess with any reinforcing nut or anything. They will never come loose.
Brian
