Weird turn signal problem
Old Jul 4, 2005 | 01:13 PM
calys968's Avatar
Default Weird turn signal problem
When I start up my car the front driver's side turn signal/running light doesn't come on. But when I set my alarm it flashes, and also if I have my headlights on it works fine.
What could be wrong with it?
Old Jul 4, 2005 | 02:26 PM
9silverbird8's Avatar
I made this exact same post awhile back.its a dual-fillament bulb. Just replace it. Quick and easy.
Old Jul 4, 2005 | 03:28 PM
calys968's Avatar
Thank you!
Old Jul 4, 2005 | 03:30 PM
Anytime.
Old Jul 4, 2005 | 04:23 PM
calys968's Avatar
Another question... how the hell does that stupid piece of **** light bulb come out???
Old Jul 4, 2005 | 04:25 PM
............twist and pull.....
Old Jul 4, 2005 | 05:27 PM
calys968's Avatar
Okay, I replaced the bulb and now the light doesn't come on period, even when I have the headlights on. What did I do wrong??? This is what I get for trying to fix it myself instead of asking my boyfriend to do it
Thanks for your help, btw.
Old Jul 4, 2005 | 05:46 PM
You didn't forget to reconnect the negative battery cable did ya?
Pull it out again, and make sure the bulb didn't break or anything obvious like that and check the connections to see if they're tight. If everything looks good and it still doesn't work, try putting the old bulb back in and see if you go back to flashing. If the old one works you just need another bulb, otherwise, you must have knocked a connection loose or something. If you have access to a voltmeter or a dummy light you could use that to make sure there is voltage.
Hope one of those works for ya and BTW you have a beautiful first name
Old Jul 4, 2005 | 06:28 PM
calys968's Avatar
I put the old bulb back in and it still doesn't come on at all so I'm gonna assume that you're right about me knocking something loose.
I guess I'll go back out there in a little while and try to figure out what came loose. I don't get it, I can change my spark plugs or do my brakes with no problems at all and when I try do something really simple like changing a bulb I manage to screw it up.
And thanks for the compliment on my name
Old Jul 4, 2005 | 06:42 PM
The 'easy' stuff always seems to take longer. Just don't let it get to ya. It'll work out. Good luck and damn thats a badass ride.
Old Jul 5, 2005 | 10:49 AM
calys968's Avatar
Now I am really confused. The new bulb is in there now and yesterday afternoon the light would not come on at all. Then I took the car for a drive last night and the light was working! It stayed on even with the headlights off. So I was pretty stoked, I thought that the problem had somehow fixed itself. This morning I start up my car and I check to see if it's still on and it's not but when I turned on the headlights it came on. Wtf???
Old Jul 5, 2005 | 04:29 PM
WhiteBird00's Avatar
Ungrounded Moderator
First, there are two separate filaments in each of the front bulbs - one for DRLs/turn signals and the other for the parking lights. When you turn on your headlights you see the dimmer parking light filament. Any other time you should see the brighter DRL filament. It is quite possible for one filament to burn out while the other remains OK.
Also, the DRLs don't go on when you start the car until you release the parking brake. Maybe that's why they didn't go on when you started it this morning?
Do your turn signals work on both sides or do they just go on but not flash? If they don't flash then you have a problem with the bulbs or sockets.
