How to replace sail panel speakers?
Old Jul 8, 2005 | 04:17 PM
2000 TAWS6's Avatar
Default How to replace sail panel speakers?
I bought a new Monsoon 6.5 inch speaker for my passenger side sail panel. ($54.29 delivered)
Is there any tricks needed to remove/replace the speaker?
Does the entire plastic panel adjacent to the rear seat have to come out (I hope not)?
Thanks all.
Old Jul 8, 2005 | 04:29 PM
shouldaboughttheZ's Avatar
The grill will pop right off. Unbolt the 4 bolts holding it in. Pull speaker out, and unclip wires attached to it. Install in reverse order.
Old Jul 8, 2005 | 04:37 PM
2000 TAWS6's Avatar
I hope it is actually that easy. You know how these things go.......
Old Jul 8, 2005 | 05:02 PM
GPz1100's Avatar
Be careful when removing the grill. You may have to use a screw driver to release the clips if they dont give on their own.
Other than that, You'll need a 1/4" or 5/16" socket to loosen the screws holding the speaker in place.
Old Jul 8, 2005 | 07:05 PM
It is that easy, unless you are like me and are 6'7" and can barely fit back there.
Old Jul 8, 2005 | 08:07 PM
2000 TAWS6's Avatar
No, only 6', 230, but it's still a struggle to get in and out from there.
Old Jul 9, 2005 | 01:37 PM
2MuchRiceMakesMeSick's Avatar
It actually is that easy
Old Jul 10, 2005 | 11:21 PM
AnimalSS's Avatar
Dude! you're 6'7"!!?? Can you actually drive an F-Body?
Old Jul 11, 2005 | 08:03 AM
2000 TAWS6's Avatar
It was. Just was puzzled by the little clips that go in the holes for the screw threads. I only found one, but new they were all screwed in tightly so the others musts have been there.
They were stuck to the old speaker magnet! Sucked up to it on the way out.
Old Jul 11, 2005 | 09:26 AM
Dano 00TA's Avatar
Hahahaha, that just made me think of that movie with Burt Reynolds....I think it was called "Gator" with that tall guy "Bones" driving that car and his head stuck up through the sunroof
Old Jul 11, 2005 | 09:38 AM
I can only fit in the drivers seat. No passenger riding here!
Old Jul 11, 2005 | 09:39 AM
I am going to try and have a write up on this for my site.
Old Jul 15, 2005 | 04:30 PM
Rescue Ranger's Avatar
My 6.5" speaker doesn't take up the entire hole in the sial panels.. I guess the hole is 6 and 3/4" ? The edge of the speaker (metal frame) hits the hole, but the holes where the screws go dont meet up with the car.. its just air behind it. Any suggestions?
Old Jul 16, 2005 | 09:57 AM
You might have to make an adapter ring out of MDF. 1/4" should be fine.
