Help! - Monsoon LOC'd
there's a code that you'll have to put it using the head unit... if you're the original owner, then you or the dealer put it in... if not, then the original owner probably activated it and set the code. From my experiences, you WILL need that code... maybe there's something that GM can do for you if you don't have it.
Good luck... if you don't have your manual, let me know, I'll type the instructions out for you later.... as for now, I'm off to bed before work tomorrow.
https://ls1tech.com/forums/wiring-stereo-electronics/303776-frequently-asked-questions.html
https://ls1tech.com/forums/showthread.php?t=303776
https://ls1tech.com/forums/showthrea...light=theftloc
These are two of many threads. At some point the code you puch in on the phone changed and the second thread above mentions that and lists the new code.
It seems that the phone system/message may have change a while back.
