lighting headaches
Old Jul 13, 2005 | 08:19 PM
stangkiller's Avatar
Unhappy lighting headaches
my corner light bulb melted to the little plug and it broke when i tried to pull it out, what can i do to fix this? also my hvac lights went out as well as the 3 and 6 on my cd player (its a monsoon) what can i do for these problems?
Old Jul 14, 2005 | 12:42 AM
ewilborn's Avatar
What broke on the corner bulb? The bulb itself, or the socket? Was it the 194 or the 3157?
As for the cd player... that might be under some sort of warranty still. My suggestion with Monsoon is just to get rid of it
Old Jul 14, 2005 | 12:38 PM
VIP1's Avatar
Copy & Paste Moderator
Midnight F-117A replaced the bulbs in his F-body Monsoon headunit with LEDs:
https://ls1tech.com/forums/showthrea...&highlight=led
Old Jul 14, 2005 | 01:42 PM
it was the 194 and the base is melted to the socket. i will have to check up on that warranty.
Old Jul 15, 2005 | 01:13 AM
ewilborn's Avatar
Ouch. Needle nose pliers MIGHT get that out... Not so sure on the warranty for bulbs like that, though. Wiring another socket in will work... I've had to do it with the 3157.
Old Jul 15, 2005 | 12:02 PM
seems like it would be pretty straight foward rewiring the socket, but i hate wires and electrical stuff its like foreign language to me.
Old Jul 15, 2005 | 12:20 PM
GPz1100's Avatar
Just get a new socket from the local auto parts store.
Snip the old socket and solder the wires from the new one to the existing wires. Polarity doesn't matter with bulbs.
Besure to use electrical tape over the connection, or better yet, some heat shrink tubing.
Old Jul 15, 2005 | 05:24 PM
i better go get a soldering iron then.
Old Jul 15, 2005 | 11:52 PM
ewilborn's Avatar
You don't HAVE to solder. In the past, I've just bought heat shrink connectors from WalMart and crimped and heated them together. Works like a charm.. no problems yet.
Old Jul 16, 2005 | 12:04 AM
i might just go that route, seems like it is cheaper and easier.
Old Jul 16, 2005 | 03:10 AM
GPz1100's Avatar
I prefer not to crimp. Due to vibrations and other factors, crimped connectors can come loose or have poor contact. The 194 wires are probably 18 or 20 gauge, so soldering should not be too difficult.
In addition, next time you need to do any electrical work, you'll have the proper equipment.
Personally, I use a little butane filled soldering iron. Comes with several different tips for doing other work such as mini torch, etc..
Refillable too.. I paid $20 for this many years back. Butane is cheap.. most places that sell smokes and lighters sell the refill canisters.
Old Jul 16, 2005 | 11:31 PM
thanx for your help i am gonna check it all out tomorrow and see what i can do.
Old Jul 17, 2005 | 01:06 AM
ewilborn's Avatar
That's where the heatshrink comes in handy... it doesn't allow the wire or connector to seperate from each other as long as it is shrunk fully and at the right place.
