Sub cuts out? HELP
Old Jul 25, 2005 | 06:42 PM
Shackelford's Avatar
Originally Posted by 96GrandAM
i dont think is the amp dude i had the same problem..how many watts is ur sub ur probably over powering it..try a nother sub and see what happens..good luck
he is definatly not overpowering a L7 (1000+watt rms) with a "360 watt rms" (I question even that) amp.
Old Jul 30, 2005 | 12:05 AM
Ls1_axxxman's Avatar
Sounds like ur amp is going into protection. Is the L7 dual 2ohm or dual 4ohm, you may have too low of an ohm load on that amp. I would highly recommend a larger amp though, L7's are bad *** woofers but they are power mongers. I got a memphis st1000d on my 3 IDQ 10's and thats honestly about the power range u need. You throw about 500-800 watts thru the kickers and you will love em.
