Starting to edit my audio
So I have a 12" Diamond Audio sub that I'm going to put in my 02 Trans Am, I'm going to make a box and it will fit in the small little cubby hole..
I also bought a HiFonics Zeus ZX4000 Amplifier 400 rms...
What else am I going to have to plan on? I have the stock Monsoon 500 watt sound system, am I going to have to change anything with it, or any recommendations from anybody or words of wisdom? Thank you very much!
In short, you will need a line output convertor to connect your amp to the stock headunit. Also, RCA's to actually connect the amp and a regular amp wiring kit. Total $$ should be around $70-$80 for all. Check out www.knukonceptz.com for wiring. And good luck with the box. Not impossible by any means, but not easy. I suggest using fiberglass if you're not already. If you haven't worked with fiberglass in the past, don't worry. I found it extremely easy to work with.
