Does anyone make a grounding kit for the LS1?
Not LS1-specific, but should be able to apply more generally: http://350zmotoring.com/forums/showt...p?threadid=186The description/definition posted in that thread says,
One of the best-proven ways to compensate for noise is with proper grounding.
When measuring a DC (direct current) signal, almost any kind of wire will due. However, when measuring a high frequency input (i.e. the mass air flow sensor or the air/fuel mixture sensor) it is necessary to run a ground wire in parallel with your signal. The engine grounding/earthing kit provides grounding along side each signal wire.
The 350Z Engine Grounding/Earthing Kit allows for cleaner data transfer to the ECU. The result is more accurate measurements by the ECU and therefore more accurate performance, smoother idle and acceleration.
I've read some of the write-ups, and I'm a cheap bastard and was skeptical. I instead just picked up some standard 10ga wire(not the car stereo grade stuff) and normal eyelet crimps to make my own grounding system.
I added a few from the block to the body (about 4), the battery to the body(just a single 10ga connection), and thats it.
I also saw the voltage reading based on my HKS Turbo Timer go up about 0.2V. Interesting change to me at least....
