Will 6x9" speakers fit?
Old Aug 21, 2005 | 12:36 AM
DarknessC5's Avatar
Default Will 6x9" speakers fit?
I won some 6x9's at a carshow. Has anyone used these anywhere in there F-body? I know the normal sizes are 6.5" just curious if I could fit a 6x9 in one of the spots or not.
Old Aug 21, 2005 | 01:13 AM
Nate_Taufer's Avatar
without some fabrication you're better off selling them and getting some 6.5's
Nate
Old Aug 21, 2005 | 11:21 AM
Platinum WS6's Avatar
yea i tried fitting a pair in a friends car and it just didnt work.
Old Aug 21, 2005 | 03:32 PM
DarknessC5's Avatar
They wont even fit in the hatch panels?
Old Aug 21, 2005 | 04:44 PM
spy2520's Avatar
The ones in the very back? Its just plastic, you could cut to make them fit. The back is 4x6 ovals i think.
Old Aug 21, 2005 | 06:51 PM
99midnightZ's Avatar
i put 2 6x9 in the back of my 93 and i have to cut out custom enclosers and use the grills that came with the speakers. it wasnt that bad but remeber you will have to run wire all the way back there which kinda sucked unless you want to hook it to an amp
Old Aug 22, 2005 | 02:44 PM
DarknessC5's Avatar
Yeah, the ones in the very back. That's what I was thinking... They look big enough to fit 6x9s if they were cut.
Old Aug 23, 2005 | 03:38 PM
CAMAROWITHBASS's Avatar
i have 6*9s in my sail panels.
Old Aug 24, 2005 | 03:27 PM
DarknessC5's Avatar
The panels in the back seat? How did you fit them?
Old Aug 26, 2005 | 01:21 PM
10thAnivHawk's Avatar
I work at best buy and the guys in the back installed 6x9's in the place where my rears were not the ones near the back seat but the ones that are back at the hatch. they had to do a little cutting but I think thats it. I'm very happy that I went with the 6x9's
Old Aug 26, 2005 | 01:35 PM
94strokedz's Avatar
I took off my plastic panels on either side of my back seat. Then I held the 6 by 9's up to the hole where the 6 and a halfs were and traced where I needed to cut out. Then I went crazy with a sawzall, and it worked out great. No problems whatsoever. I did it to my 94 Z28 as well as a friends 98 firebird. It was pretty easy. 6 by 9's put out much better mids under power than 6 and a halfs do.
Old Aug 27, 2005 | 06:01 PM
No doubt about it you will be much more pleased with your mids. go for it!
Old Aug 29, 2005 | 12:38 PM
InfiniteReality's Avatar
This will be my next mod...
