howto on wiring up a convertible switch w/ cutout?
sweet it works muaahaha its alive!!! The problem was the power i wasn't hooked up right than i used a tapin and it worked, the switch works flawlessly. The only thing is that i have it so when you press it UP the cutout closes i want it to close when you hit DOWN so i am just going to reverse that. I also wired up B and C but the one last thing i need to ask you is where do i wire it so that it can get light from the dash? What do i tap into? Right next to door to this switch is the TCS which has a light always on however it is connected with a sealed connector so i am not sure how i would tap into that. Anyway thanks for taking the time to help me you have been very useful and patient and i hope that others can refer to this because its actually quite easy to hookup the switch i just over looked one lil thing doh!
I think i'll just tap into that wire than i should have no problem doing that correct same difference? Hey also i read in another thread where you were responding to people inquiring about how to hook they're ipod's to they're factory monsoon stereo system, i could do that correct since i have a 2002 it should have the cd changer input on the back although i do not have a cd changer? I have a single cd. Thanks.
Thanks agian, which do you recommend, the GM9-AUX i found on a site for 69.99 on sale, whereas the icruze is upwards of 200. Will the GM9-AUX allow me to use the steering wheel controls? Thanks.
Ungrounded Moderator
The GM9-AUX adapter is merely an auxiliary input adapter - all it does is connect the iPod to the stereo system without using FM modulation. Your steering wheel controls will still work but they won't do anything to control the iPod.
The iCruze provides limited control of the iPod through the radio. It just passes the CD controls to the iPod so that you can skip back and forth between tracks and playlists. The unit only handles special playlists that you make up in advance - you can't just browse your music.
The whole question is a moot point because Monster doesn't make an interface cable for the 98-02 Monsoon systems so the iCruze won't work. Save your money and get the GM9-AUX.
Hrm so the GM9 won't allow me to control the IPOD through the radio...that is a bummer, is there an adapter or something that will allow it to? What do i basically do just use the ipod as i normally would and i can play any song etc than just use the ipod's controls? I like the idea of using the stereo to control next song, stop, play and volume, i know there are other units out there but i want to find someone who has such a unit for the monsoon.
I found the IPOD2CAR by peripheral electronics, it allows you to retain ipod control aswell as controlling the ipod through your steering wheel and radio, a bit pricey though weighing in at about 180 or 150 on ebay.
#32
The GM9-AUX just lets you connect the iPod to the radio as an external auxiliary source. That means you can switch between iPod, radio and CD using the radio controls and of course the audio controls (volume, tone, etc.) still work the same. You would have to use the iPod itself to select the tracks to play.
You really should start a new thread to continue this discussion.
#33
Originally Posted by qwik3r
Hey just out of curiosity what would it take to rig up a light or something so that when the cutout is completely open or closed it will lightup?
#35
Does anyone know how to wire this up for a cutout with the 4 wire setup where you push a button and it goes all the way open or all the way closed and then stops? Please post it if you can or PM me. I hate having this cutout just stuck open.
