will my setup work? help please!
Old Sep 6, 2005 | 12:06 AM
lferdzl's Avatar
Default will my setup work? help please!
im getting 3 10" subs, box, 1000watt 4 channel amp. I was thinking of just keeping the stock monsoon cd/am/fm deck. What will i need besides the basic amp kit to install my amp to the stock deck? i know the amp kit has rca cables that you connect the amp to the deck. my main concern is does the stock deck have rca cable inputs? what should i do while still keeping the stock deck? is it even possible? any input is much appreciated. thanks!
by the way, if it does turn out i could use the stock deck, which wire would i splice into for the lead turn-on wire? any diagrams write ups on this?
Old Sep 6, 2005 | 01:23 AM
Josh_101's Avatar
If the amp has high level imputs you can use the factory head unit with it, and no, the factory HU doesn't have RCA outputs.
Old Sep 6, 2005 | 03:13 PM
lferdzl's Avatar
here are the details of the amp i will be purchasing. will this work?
250 Watts X 4 Output
500W x 2 Bridged Output (250 x 2 + 500 x 1)
Dual Variable Hi/Lo Electronic Crossover Network
Dual Variable Bass Boost (0 - +18dB @ 60Hz)
Variable Input Level (Gain) Control
Remote Turn On/Off
Gold Plated RCA Inputs
High Level Molex Input
Power On LED Indicator
LED Protection Indicator
S/N Ratio: > 95dB
THD: < 0.04%
Frequency Response:15Hz-30 KHz
Thermal Protection
Overload Protection
Short Circuit Protection
Anti-thump Turn-on
Tri-Mode Configurable
Blue LED Level Display
Dimensions:10.9''X2.7''X12'' (WxHxL)
