RCA subwoofer output?
Old 09-14-2005, 05:31 PM
Pavetim's Avatar
Default RCA subwoofer output?
Does the stock monsoon radio have RCA outputs for a subwoofer?
Old 09-14-2005, 06:15 PM
Josh_101's Avatar
The search feature is your friend.
Old 09-14-2005, 07:04 PM
zorrander's Avatar
Quite correct... but no it doesn't...
Old 09-14-2005, 08:18 PM
f0xball's Avatar
Not without a line level converter pac and peripheral make nice ones.
http://www.themorphics.com/index.asp...D&ProdID=34801
Old 09-14-2005, 08:21 PM
f0xball's Avatar
Ohh you can use the high inputs on most amps but that is normally a pain and you throw off you ohm load on your speakers alittle
Old 09-14-2005, 08:25 PM
redline2k's Avatar
YOu can grab the sub out put from one of the 6.5's in the rear side panels. Make sure you get a high wattage adjustable loc or you will have problems. You can also get a full range signal behind the radio.
