Monsoon Display
Really it's not that hard if you have an understanding of basic soldering techniques (a fine tip iron helps too
) If you run into problem PM me and I'll help out
glad, I'm not the only one that was able to get this to work. Yea once inside it only takes a few mineuts to knock it out ... and once you've take the radio apart the whole thing from removal from the car to reinstalling it back in only talke about 10-15 min and that's if you forget to plug in the soldering iron when you get started so it's hot when you get it apart
this should get your display fixed rock solid! for the volume issue get some good contact cleaner and spray in the area where the pole for the vloume **** goes into the "box" attached to the circuit card. right after spraying ... turn the hell out of the **** ... spin spin spin ... keep spinning it ...
ok now just like shampooing your hair ... spray and repeat
once you get everything back together you "should" have a solid display AND volume should be working fine
OH GOSH ... almost forgot ... check the connections on the circuit card for the "box" for the volume .. make sure there are no cracks in the solder connections there either ... that could cause "poping" and cutting in and out too
If you run into a problem PM phone # and I'll call as soon as I get it, I don't have AIM and I'm barely on yahoo ... joe_kool315 there too
, then you can see the track number.Also I don't listen to the radio and I don't like the way the car looks with the antenna up, can I disconnect this without the car "coding" on me???
Thanks, Sorry to bring up an older thread.
I finally got around to doing this today. I hit all the points that were mentioned with a hot iron, but didn't use any solder. I just tried to reflow what was there.
I can now see my display, but ever so slightly. Does this mean that the bulb is OK, or should I look for a new bulb? Should I try hitting the solder points again?
I didn't use new solder cuz what I had was too big and I didn't want to make a mess.
