Monsoon Display
Old Jul 5, 2010 | 03:33 PM
  #41
Viper's Avatar
Bring it up again. 5 years later and this really helped; just did it on mine. Only did a reflow and it fixed it. Thanks to the OP!
Old Jan 20, 2011 | 08:22 AM
  #42
OldCobraGuy's Avatar
I know this thread is old, but the problem with the display is still valid. I had to replace the bulb and couldn't believe the price that the suggested supplier was charging. So I did some research. The GM part number for the bulb is 16208443. You can check the price yourself and find it MUCH cheaper. But I went further and found an authorized GM radio service center who sold it to me for just under $2.
Old Jun 13, 2011 | 12:24 PM
  #43
wssix99's Avatar
Save the manuals!
Best thread ever. It keeps on giving and giving. Just re-soldered the display leads and chip and the display is back and clear again!
Old Sep 29, 2013 | 03:20 PM
  #44
wes1972's Avatar
OK not to bring up another time. but I am getting ready to resolder mine. Do you have to do anything with the theft loc before you take it out
Old Apr 27, 2017 | 09:42 AM
  #45
sherbin18's Avatar
This is an old thread, but my Monsoon every once in a while does not respond to either the unit controls or the steering wheel controls. Since the car is a convert and I live in Florida (where the weather is hot and the sun even hotter), I think I have to go in and check the circuit board(s) for cold solder.
It's only an intermittent problem and goes away most of the time. It does not happen when I start up in the morning, only when it's been on for awhile.
Old May 28, 2017 | 06:55 AM
  #46
sherbin18's Avatar
I think the problem was an iphone bracket that I was using. It was one of those that mounted into the CD drive. When the "problem" occurred, I removed the bracket and voila, the problem went away. It went away when I took the iphone off the bracket.
As best I can deduce, the weight of the iphone/bracket combination caused a downward pressure on the front radio panel, distorting something behind the panel.
Long story short, time will tell.
