Installing subs and amp
Old Oct 4, 2005 | 03:51 PM
BeemerZ28's Avatar
Default Installing subs and amp
Okay guys I am at a loss right now. I am trying to add (2) 12" Kenwood w3009 subs along with a kenwood 9102 amp. Now here is my problem I am adding to the existing Monsoon sytem on a 2002 Z28, so i am using speaker level inputs for the amp not RCA cables. I can not for the life of me get the damn thing to stay on. I wired everything up and I can get the amp to turn on momentarily but then it shuts off. I am just looking for some advice from some people that have maybe added subs and amp to stock monsoon system? Please help ASAP
Old Oct 4, 2005 | 03:55 PM
zorrander's Avatar
What are you using for the amp turn on lead?
Old Oct 4, 2005 | 04:32 PM
86Z28's Avatar
he should be using either a relay or a switch with relay.....
Old Oct 4, 2005 | 04:34 PM
zorrander's Avatar
I was thinking he may not be getting enough power to the turn on lead on the amp... maybe a bad relay? Could be tripping a circuit protection in the amp itself too... don't have much experience with speaker leads.
Old Oct 4, 2005 | 05:20 PM
spy2520's Avatar
on my last car i just tapped a into an ACC fuse wire behind the fuse box.
Old Oct 4, 2005 | 10:33 PM
BeemerZ28's Avatar
yeah i am plugged into the acc slot in the driver side fuse box with an automotive tab. The instruction manual says that it has some kind of protection feature to it so if any wire has a short circuit then it will shut the amp off. I hate wiring when it goes wrong.
Old Oct 5, 2005 | 12:02 AM
GPz1100's Avatar
Maybe instead of having a direct line from the fuse tap to the amp, you should install a load of some sort (1kΩ or similar) inline....
Old Oct 5, 2005 | 07:44 AM
zorrander's Avatar
Or get a new head unit with an amp turnon lead...
Old Oct 5, 2005 | 11:29 PM
BeemerZ28's Avatar
i think i am going to pul the box and see about connecting everything to a friends car and see if it is my wiring that is the problem or the amp itself. He has an aftermarket head unit, so ill be able to check things with rca's too
