UNDERDRIVE pulley probs = 9v HELP !!!!!!
Originally Posted by Jpr5690
That just means you want 1 path to ground for each component in system. It doesn't mean they have to have the same route to ground. Ground loops are a problem because they can act like an antenna and cause noise in sensitive systems. The 12V system in the average car is so noisy as to make no difference.
only 1 path taken they are all on seperate cables just grounded in the same location ..i.e. 1 bolt 3 wires off of it
