Another Alternator gone
Old Oct 11, 2005 | 12:03 AM
blackbird345's Avatar
Default Another Alternator gone
Please help. I have gone through about 4 alternators now. Was having a wierd problem with lights dipping when I first move off then it would go away. Now I got that problem fixed, went to test it tonight after just getting the alternator rebuilt. Put it in and took it for a spin. After about 3 mins I punched it and blew the alternator. Is there a break in required? Is there any upgrade I can get?
Old Oct 11, 2005 | 01:01 AM
95stroked1500's Avatar
? where are you getting your alts?
check for shorts/ bad connections. how's the fusable link?
is there an external voltage regulator that could be shot
test for the voltage at the + post on the alt.
Old Oct 11, 2005 | 04:24 AM
ultraz's Avatar
there is a technique for installing alternators, I've heard of similar experiences and it causes premature seizing. Look it up, or hopefully someone who knows can chime in.
Old Oct 11, 2005 | 08:20 AM
shouldaboughttheZ's Avatar
Are you running a aftermarket sound system?
As posted above, where are you getting them from?
Old Oct 11, 2005 | 01:49 PM
Discount Auto Parts, and then it was rebuilt locally (no discount auto parts here in the Cayman Islands. Its not seized, but just not charging....would i need to put a resistor in the line like what some people r doing?
Old Oct 11, 2005 | 08:43 PM
Update:
Thank you all for your contribution. After looking at the alternator again, apparently when I floored it last night it pulled the small wire out of its connection. I'm missing the actual clip so the wire came loose. Hooked it back up and so far so good. THanks again.
Old Oct 12, 2005 | 06:59 PM
Update on update:
Having a problem with voltage going down when I accelerate hard up to about 6000 rpm's is this normal?
Old Nov 20, 2005 | 08:32 PM
Update: bad rebuild, wrong parts used I guess. Got another alternator and its working ok. Thanks everyone
