2 ohm speaker off HU?
KAPPA62.7I
Specifications:
Power Handling, RMS: 75 Watts
Power Handling, Peak: 225 Watts
Sensitivity: 94dB
Frequency Response: 45Hz - 25kHz
Mounting Depth: 2-3/16"
Impedance: 2 Ohms
Can someone who knows about this stuff tell me what I can expect by running a 2 ohm tweet off the 4 ohm HU? There's been discussion about running the 4 ohm 6.5 off the amp, but not vice versa. Thanks a lot!
Other than that, they should be decidedly louder than the stock tweeters were.
Have you looked at the Image Dynamics CXS62's? These components come with a 4 ohm Tweeter and a 2 ohm Midbass.
They are priced at $279 from these guys:
http://www.carmedia1.com/en-us/dept_19.html
In the arrangements that use the h/u channels... they are powering the 4 ohm tweeters. Hooking up a 2 ohm woofer and driving bass is a much different scenario.
It might work for a little bit but I wouldn't do it unless you are looking for a reason to upgrade your deck.
I'm glad to hear that Sunset has had good luck with these speakers so far. But head unit failure is a risk you take with this set-up.
If one of you is willing to send me your HU, I can disect it and analyze the capabilities of it's guts. Then we would know for sure what the HU can and can't do.
For ALL f-body Monsoon setups, there is not a single one where the h/u drives a 2ohm speaker, tweeter or otherwise.
The only thing the head unit ever drives are the 4 ohm tweeters. H/U power is good enough to make tweeters loud enough to keep up with the basic factory amp. In verts... the H/U actually powers no drivers at all.
In all honesty I would suspect that the amp section of the factory h/u isn't upgraded much if at all from a regular Delco. Most of which use a combination of 4 and 10 ohm speakers, or at max 4 4ohms.
As far as your 2ohm speakers working... if they are real 2 ohm speakers and you are sending a full range signal to them - I would say you are lucky that the h/u is still working. I also suspect if you crank it for an hour or so your CD's are coming out feeling like hotcakes.
However if you are using not driving bass, or the speakers aren't quite 2 ohm... then that might be ok. It's the heavy, sustained power drain of a 2ohm bass load that would kill it, for sure.
I guess in reality a factory h/u isn't that much of a gamble. But it seems like a bad long term plan.
