Meissen's Project CarPC Thread
I really think you need to get a DMM so you can test a few things. Make sure the power and ground wires are not loose and getting good voltage to the Opus. If it really looks like a problem with the Opus you can contact:
tsupport@opussolutions.com
and describe the problem to them.
Do you have a copy of the Opus 150 PDF file? It shows some trouble shooting steps for interpreting the green status LED.
Looks like I won't have the carPC up and running for my car show on the 14th. 80+ fbodies and I have to explain why the carPC doesn't work again.
http://www.pcguide.com/ref/power/sup...erboard-c.html
If you can get a digital DMM (maybe you analog will work), pull the purple wire out of the molex connector and put you meter inline so that power will flow from the PSU through the meter and to the purple wire. Plug in the inverter and AC PSU. Now you can see what the draw is on the 5vsb wire. Unplug the suspected USB devices one by one and see how much the current draw changes. Tell the warranty guys the milliamps it draws and ask if that is about right. I personally have no idea what the 5vsb should draw, but it can't be any higher than what the dc-dc PSU was drawing in total when powered down.
it's not too much different then a regular computer, start throwing extra cards and drives in one and the PSU just can't meet the initial power on wattage needed.....
have to explain to 80+ people that my PSU decided to just stop working and that's why it's ghetto rigged with an invertor... good publicity for Opus
) so I've slacked on taking it out. I have the RMA number to ship it back, just a matter of doing it. I'm at the point where I'm ready to just demand a refund and get a more stable PSU. It worked great for over a month, then literally just stopped working when nothing had changed. if it will power on without all the accessories then you know you have a weak (Not doing as rated) power supply, but you could still use the basic functions. from the e-mail the tech sent you it sounds to me like this is what they think.. I have also read that some usb gps use a rather abnormal amount of power at power on and then drop, which is pretty normal for almost all electronics...
I know I would rather go to a car show and say "The company shipped me a power supply that wasn't putting out rated power so I can't use all the functionality I have installed" rather then "Yeah that's my ghetto rigged power inverter.
anyways it sounds like thier customer service needs some work....
Anyway, did you measure the 5vsb current? You could also just cut that purple wire and put the meter inline and then solder it back together when you done.
