How to: Electric Cutout wiring HELP!>!?!?!!?
Old Nov 8, 2005 | 05:01 PM
z28C4maro82z's Avatar
Default How to: Electric Cutout wiring HELP!>!?!?!!?
Please I need some help here
I got the switch, I got the wires all ran underneath the cutout hooked up and now I need the wires to the switch. I've no idea on how to run them to the actual switch itself. There were 8 wires connected to it and just need to know how to run the wires. I'm so lost
PLEASE HELP THANK YOU
Old Nov 9, 2005 | 07:18 AM
WhiteBird00's Avatar
Ungrounded Moderator
What happened to the instructions that came with the cutout?
8 wires? Most cutouts have only three. Are you using some other kind of switch other than the one that came with the cutout?
Old Nov 9, 2005 | 08:54 AM
01pewter2001z28's Avatar
Here is a tech article on how I did mine
http://www.01pewterz28.com/dmhecutout.htm
Old Nov 11, 2005 | 11:47 AM
Hey man that's great but hot exactly do I wire the switch. I understand completely how to run the wires and te way you have is exactly how I am. But how exactly do the wires run up to the switch and cross and all.
Old Nov 13, 2005 | 12:26 PM
AronZ28's Avatar
I cut the wires to my cigarette lighter and spliced them in there. Lighter still works(I don't ever use it though), and the switch for the cutout did work, until I went with a different setup. If you do it my way, do not use the lighter socket and open the cutout at the same time.
