Courtesy lights not working....
Could someone measure the value of the resistor in this picture?
Kostya_F: If you get an answer on the resistor value, please post it here.
Time for some more research into the BCM....
However, everything else will work so it would be worthwhile to plug it in and see if it solves your lighting problem. Then it just becomes a matter of finding which of the 14 resistor values matches the used BCM's programming and getting a matching key made (or doing a VATS bypass). You can buy a kit that allows you to select each resistance value without having to solder together a bunch of individual resistors for each possible combination. For that matter, you've got a 1 in 14 chance that your existing key will already have the right resistor.
Oh, and before somebody tries to correct me that there are 15 VATS values - GM produced 15 different VATS key combinations but only 14 of them were ever used in F-bodies.
thanks in advance
TTa - I don't have any tools to measure that resistor value, am trying to get a buddy to do that for me this weekend.
Correct me if I'm wrong, but won't the ohm meter give a false reading when the resistor is already attached to the circuit?
thanks!
Thanks for the help!
