Valentine 1 Mounting
Old Nov 28, 2005 | 10:50 PM
HowellSoccer88's Avatar
Default Valentine 1 Mounting
Anybody who has a V1, where'd you put it? Our windshields are so long that when it's at eye level for me, the thing is half way down the damn windshield and I wanted to run the wires up to the top so it looks clean.
Old Nov 29, 2005 | 06:08 AM
2MuchRiceMakesMeSick's Avatar
I mounted mine as high as it would go on the windsheild.
That way its hard for them to see when I get pulled over.
Old Nov 29, 2005 | 09:52 AM
spy2520's Avatar
mine is mounted up pretty close to the tint strip, its just below it and i have the wires run up through the headliner, can barely tell its there.
Old Nov 29, 2005 | 10:15 AM
JoeyAnderson's Avatar
Post up pics if you can!
Old Nov 29, 2005 | 10:23 AM
thaar's Avatar
I've got mine right at the tint strip right next (or kinda above and to the side) of my mirror. Have it hardwired to the fuse panel running the wire through the headliner then down the a-pillar.
Edit: Here's a good website that has a pic of it mounted and how to wire it http://www.xse.com/leres/ss/v1.html
mines not that far over to the right, but close.
Old Nov 29, 2005 | 04:47 PM
clemsondave's Avatar
Same as thaar, but I wired in the hidden display and cut out the trim panel around the radio to flush mount it.
Old Nov 29, 2005 | 05:01 PM
jimbonzzz's Avatar
Mine is hardwired, and it is mounted kind of above the rear view mirror, on the drivers side of it. I use the visor clip and clip it directly to the headliner. I find this to be much more stable than using the suction cups.
I run a wire down the A-pillar and I also have a kill switch for it on the side of the console.
My remote display is mounted with the instrument cluster on both cars.
Here's a pic on the firebird:
Old Nov 29, 2005 | 09:07 PM
shortdo99's Avatar
Same here, hard wired above and just a lil to the right over the mirror.
Old Nov 29, 2005 | 09:46 PM
Slammed-am's Avatar
Ditto!
Old Nov 30, 2005 | 07:10 AM
btw, it saved my @ss again this morning. Doing three digits when it started talking to me.
Old Nov 30, 2005 | 12:43 PM
Ive really been wanting to do this but I havent had time to do it
Ill also move the display to the left of the mirror.
Old Nov 30, 2005 | 02:00 PM
thaar's Avatar
Very nice install.
I have the separate unit as well, but don't use it. Most people from the outside can't see that I have a radar detector anyways.
Old Nov 30, 2005 | 02:51 PM
jimbonzzz's Avatar
Great Lakes Trophies sells mounting brackets for V1 and Escort detectors that bolt right up to the stock rear-view mirror bracket of C5's and C6's that look pretty cool. I have also heard of some people using them on the fbods..
Jim
Old Dec 1, 2005 | 01:15 AM
Jim
Those arent too bad
Old Dec 20, 2005 | 11:31 AM
BoneSS's Avatar
Is the only way to hardwire using the fuse panel writeup mentioned above?!?
Old Dec 20, 2005 | 05:44 PM
No its not the only way but it is the easiest IMO. A few buddies of mine have hardwired theirs off of the TCS or rear defrogger switches. The radio also has a power output that can be tapped in to.
