AMP for 2-12" L7's????
I need to get an amp that can handle two 12" L7's. What do you guys recommend. I was just going to go to the store to see what they had, but I don't want to get talked into buying a P.O.S amp that will only work for a few days. What amps are you guys using and what should I use for this setup. Thanks in advance!!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
hey ive got 2 L7s running off of an older mtx amp. its either a 81000D or 8100D, i cant remember which. it puts out 1500watts rms at 14.4 volts and im pretty sure the kickers handle 750 rms a piece so 1500 between the two. but the combo works great together, no problems other then blowning the battery and alternator haha.
