newb needs help with speakers/wiring/amp
Here's a quick thread with what I did.
Go for the infinity references if you can get em' cheap, they'll work fine. Honestly I'd point you to the search button but the search is currently borked
I'd HIGHLY recommend a 5-channel amp.. less mess, and there really isn't any place to put these things, so having one unit makes it helpful. You can use your monsoon speakers, check the 'Sticky' at the top of the page on info how to do this, but since you get mad discounts, just do everything, amp, speakers, sub, etc.. it'll sound incredible. I don't regret for 1 second the cash I spent.
I got a dual voice coil sub, and ran it positive to positive, neg to neg, to 1 channel, which runs a 4 ohm sub @ 2 ohms, and it slams.
See if you can get a decent 5-channel amp, 4 guage wire kit, 10" sub of your choice really, that'd be something to look through the threads on, and those infinity references or the Polk silk tweet coaxials you sell also.
The voice coil of the speaker in combination of how its wired determines the resistance that the amp will see.
The ohms rating has nothing to do with the quality of the sub.
It wont sound bad. It will just resist more electrons meaning you wont get as much power to the speaker. Basically it just wont be as loud.
Be careful when comparing Sensitivity specs between speakers. I've noticed that different manufacturers use different standards. All are given in dB which is a measure of sound pressure. And are usually measured at 1 meter in front of the speaker. The difference is the input to the speaker. Most common Sensitivity stats are measure with an input of 1 Watt(rms) of power. This would be an input of 2 volts across a 4 ohm speaker (1.414V for 2 ohm). The other common yard-stick used is a speaker input of 2.83V (2W across a 4 ohm, or 4W across a 2 ohm load).
