Electrical Issues.....HELP!
~No Radio, won't even power on.
~No Speedometer, Odometer, Tachometer, fuel or temp gauges (volt and oil pressure still work and gauge backlights work as well)
~Hatch release doesn't work at all, I have to use a key
~Fog lights/parking lights no longer blink when I lock/unlock the car though they work fine when I turn them on and my keyless entry still works...
Any idea what might cause all these misc. little things to go wrong, it is quite annoying. Thank you for your help.
~Paul
As for the hatch release, there are a few possible issues. First, I believe that this is also routed through fuse 7 but I can not confirm that. Other requirements for hatch release are an engaged emergency brake (manual trans) or shifter in park (automatic). If these requirements are met and it still doesn't work, it may be that your battery is too low to cause proper release. In my case, I ran down my battery by having the lights on while troubleshooting my issue. When I finished the trunk wouldn't release until I charged the battery. I hope this helps.
