LS1 monsoon system compatable with LT1 TAs?
I am about to purchase the whole monsoon system out of a 99 Z28 i believe, curious about 2 things:
1. Do they all have the same setup from 98-2002
2. Do they work with the 93-97 TAs
Ungrounded Moderator
The biggest problem installing in a 93-97 model will be the speakers. I don't know what size speakers can be mounted (my 95 had a Bose system which was completely different). You might want to check that before tearing it apart.
The sound quality of a Monsoon system isn't bad for a factory system but I doubt you'll find it good enough to be worth the amount of work involved in mounting and wiring. For example, the Monsoon amp is mounted in front of the spare tire and powers all except the tweeters. So you have to wire from the HU to the amp as well as from the HU to the tweeters (and then from the amp to the other speakers, of course). You might want to consider a good aftermarket system instead.
