Will a Kenwood work in place of the monsoon?
Old Jan 31, 2006 | 02:58 PM
FLTransAm02's Avatar
Default Will a Kenwood work in place of the monsoon?
Im about to change out my stock monsoon head unit for an aftermarket. Will this amp work: http://www.cardomain.com/item/KENKDCMP828?vq_id=none
? What else should I know about doing this..I'm an audio newb..thank you.
Old Jan 31, 2006 | 03:19 PM
ded71's Avatar
I just put that same head unit in my car, it will work fine. Check the FAQ it will give you the part #s of the other items you will need. Oh, and by the way, that H/U is $100 cheaper on e-bay!
Old Jan 31, 2006 | 06:58 PM
I know, I just didn't want to give out the ebay link :0, even though the one I found was a factory-refurbished..
I am very curious what you think about the head unit, and how the rest of your system is (what you have)..I want as much review as possible, as Im always hesitant about changing things in my car. thx.
Old Feb 1, 2006 | 03:22 PM
ded71's Avatar
As far as the H/U goes I am very happy with it. Alot of people on the board seem to have Alpines or Pioneers, as do a number of my friends, But I did some some research and found that, for the money, the kenwood was a good bang for the buck. It has all the options I was looking for, 3 RCA outs at 5 volts, WMA, EQ, crossover, aux input, and a ton of other stuff.
I have 2 amps hooked to it, old rockfords, still kickin'. A 2 channel bridged to 1 to power my sub, ( jl 10w3v2-D2) in a jl stealth box. I also have a 4 channel to power my doors and sail panels. I have Infinity kappa components in the doors, and kappa coaxs in the sails. I think the system is pretty slammin'. The difference between what I have now, and what I had,(stock monsoon) is night and day.
Good luck with your install, any other questions let me know I'll give all the advice I can.
Old Feb 4, 2006 | 10:59 PM
So this headunit will be fine to buy if im only going to have a 10" sub *stealth location, with 1 amp? Any recommendations on things to do for my system?
Old Feb 4, 2006 | 11:09 PM
2MuchRiceMakesMeSick's Avatar
That head unit will work.
Here is the parts youll need
https://ls1tech.com/forums/showpost....20&postcount=5
Old Feb 5, 2006 | 12:07 AM
toomuch: could you PM me or reply me your AIM/AOL sn? id like to talk to you for a few.
Old Feb 5, 2006 | 04:31 PM
So regardless of what head unit i get, if i get anything aftermarket i also have to buy that stuff?
Old Feb 6, 2006 | 02:49 PM
ded71's Avatar
Yes you will need the antenna adapter, wiring harness, and the H/U mounting kit, with any H/U you buy. Unless maybe you get one of the Larger H/U (din and a 1/2?) I have never had one of these so I'm not sure. But for the most part you will need those parts. Should only be like $45. If you order from crutchfield I think they throw in that stuff.
