Need help picking some good speakers.
ClemsonDave is right, for a T/A use components for the doors. SInce the amp is already crossed for the woofer, you'll only need the crossover for the tweeter side.
Also, the stock sail panel speakers have 2 pairs of wires to each because they are dual voice coil. You only need to wire your replacements to 1 pair of wires only.
I'm not sure why GM used different speakers in the Camaros than the ones in the Firebirds. It makes sense that convertables have different sail speakers altogether. Due to both space restrictions and the fact that there is no rear hatch area speakers.
I also agree with ClemsonDave that you should go to a local retailer and listen to different speakers. Everyone has different tastes, and you want what sounds good to you, not what sounds good to any of us fools.
Im just curious as to what people have put in the same type of car and thought it sounded good, as I am just looking for something at least as good as stock...
I need to know what would be a good speaker for the sail panels too...
help us out guys
lemme know how those sound. I want to be sure before I buy new midbasses for the sails.
So 2 sets of wires going to the sail panel subs... meaning the subs are dual 4-ohm?
(which would convert to 2ohm for single-coil subs)
Also, did you get your subs? How was the mounting depth - did they fit?
I've considered these:
http://www.edesignaudio.com/product....=Specs&cur=USD
But am unsure as to the mounting depth.
Heres a wiring tuturial for you:
http://www.phoenixgold.com/2004/wiringtutorial.html
People are saying to "buy a 2ohm sub so it'll fit the monsoon's output," but finding out that there are 4 wires (Firebird non-vert) makes me think any 4ohm DVC would fit the bill - since it can be wired to 2ohm.
I just took out an Eclipse 10" 4ohm DVC wired at 2ohm for a 720rms amp (brain rattling) - need the space back for the t-tops. Now I'm looking to replace the blown sail panel subs with something that won't blow so quickly.
I'm not an expert on speaker physics, but I do earn a living as an electrical engineer. What I do know understand about electronics and physics leads me to believe that there is little advantage to 2ohm impedance when talking about small speakers such as the 6.75" midbasses in the Monsoon system. From what I can see, the same goes for DVC 6.75" speakers (as if you could find many of them).
My recommendation has always been to replace Monsoon speakers with a decent mid-priced off-the-shelf speaker with high sensitivity and good frequency response.
Unfortunately, I've not actually heard these. And I have not yet seen a post from someone who has installed these.
dont worry about the HU, just run the speakers off a amp.
one set of components up front off a amp and a decent HU is all you need. then you can add a 10 or 12in sub for your liking.
also dont worry about the stock wiring, run all new wires.
Whatever speakers you get, spend an extra $200 and get a half way decent head unit. You can buy $2k speakers, but they will still sound like crap with the stock HU.
