Easiest way to remove HU?
Old Feb 12, 2006 | 12:54 PM
5.3litre's Avatar
Default Easiest way to remove HU?
How can you get the stock HU out? i tried a couple of different things but i was afraid to snap anything. So how is it done? thanks!
Old Feb 12, 2006 | 02:20 PM
VIP1's Avatar
Copy & Paste Moderator
Details, Details, Details.....
What car/truck/plane/boat/tank/other are we talking about?
Old Feb 12, 2006 | 04:25 PM
5.3litre's Avatar
2001 ws6.. sorry
Old Feb 12, 2006 | 07:08 PM
98boxer's Avatar
Pull on the trim that surrounds the radio. At the very top you will have one or two connectors connected, one/two, too ASR or Foglight button, depending which you have or if you have both. So take off the trim, becarfull not to yank the top part of the trim before disconnecting the connection/s. And that it. To put it back, connect the wires to the Asr or Foglight and push trim back in making sure the pins are lined up to the holes.
Old Feb 12, 2006 | 08:15 PM
5.3litre's Avatar
thanks for the help but im still not quite getting it. my foglight switch is right under the dimmer swith and the asr isnt even close to the radio.
Old Feb 12, 2006 | 09:06 PM
kraaazymike's Avatar
Hes actually talking about taking out the bezel for the camaro.
For us, we dont need to worry about any wiring. The bezel pulls straight out from the dash. Personally I start prying my way from the top right using a flathead screwdriver and work my way clockwise pulling it out straight. I stick it in between the bezel and the radio. Once you get that off theres two bolts youll need to unscrew that hold the radio into the dash itself. Voila!
Old Feb 13, 2006 | 06:35 PM
5.3litre's Avatar
ok cool..thanks
Old Feb 15, 2006 | 08:11 PM
VIP1's Avatar
Sorry, I'm late in responding.
Check out this thread from a while back:
https://ls1tech.com/forums/wiring-stereo-electronics/351228-how-remove-bezel-front-radio.html
I posted a video there as well.
After you pull off the bezel, there are 3 screws holding the headunit in place.
