bypassing the headlight switch from emergency brake??
All you need to do to disable the automatic headlights is lift the top dash panel and crimp on a scotchlock connector across the two light green with black stripe wires that go to the daylight sensor. This will make the system think it is daylight all the time and the automatic headlights won't go on (the headlight switch will still work normally).
) You remove it by first taking off the A pillar trim and then gently prying the dash panel up. It is held on only by a combination of push-in clips and velcro.
