Nothing works!!
Old Feb 20, 2006 | 09:32 PM
nokeman's Avatar
Default Nothing works!!
I was installing an aftermarket HU today and I didnt tape ALL of the wires. Im an idiot I know. Well now I have no tach, speedometer, or trunk release. I checked every single damn fuse and they are all good. Any ideas why nothing is working now and anything I can do to fix the problem?? Thanks guys!!
Old Feb 21, 2006 | 05:02 PM
nokeman's Avatar
Nobody can help me??
Old Feb 21, 2006 | 05:39 PM
Xtremespeed's Avatar
Did you check all the fuses under the hood and inside? Almost sure you blew a fuse somewhere.
Old Feb 21, 2006 | 05:41 PM
nokeman's Avatar
Yeah they are all good. I pulled each little bastard one by one. It doesnt make any sense and its starting to aggrevate me.
Old Feb 21, 2006 | 05:42 PM
nokeman's Avatar
Thats a pretty solid time for you mods by the way. Nice job!
Old Feb 21, 2006 | 05:55 PM
Thanks! Do you have anything else that doesn't work? Does the hu work?
Old Feb 21, 2006 | 06:03 PM
firebird97's Avatar
have you ripped into your dash and computer and ran a meter to try and hunt down the problem??
Old Feb 21, 2006 | 06:05 PM
firebird97's Avatar
it could be as simple as some blown resistors, or... something more serious
Old Feb 21, 2006 | 06:22 PM
I skimmed over the wiring diagrams right quick. It looks like the fuse for the gauges runs straight off the ign switch. Doubt that's it. Are you sure you didn't accidentally cut through a ground wire, or remove a ground point bolt. Nothing in the hu wiring should affect the gauges as far as I can tell. If you need any diagrams or anything, I have them. Let me know.
Old Feb 21, 2006 | 09:32 PM
nokeman's Avatar
I definately didnt cut any wires. What happened was I left some untaped when I put them in and they touched and sparked. That would make me think I blew a fuse but they are all good. What is a ground point bolt. Also, "firebird", how do I find out if its a blown resistor and how do I fix that.
nokeman's Avatar
And no the head unit does not work.
Old Feb 21, 2006 | 09:33 PM
nokeman's Avatar
Also, the lights dont work when I lock and unlock my car. The horn only beeps once instead of twice like before.
Old Feb 21, 2006 | 09:43 PM
A ground point bolt is a bolt that holds a ground wire to a piece of the chassis. Thats not your problem though. If the wires sparked and then everything quit, you blew a fuse or possibly burned a fuse link wire. It's like a wire with a fuse built into it. Usually close to the battery or fuse block, and heavily wrapped. Makes the wire look like it has a real thick spot in it. When you checked the fuses did you use a meter or a test light, or did you just look at them. It really sounds like you have blown a fuse or 2. I have seen them look fine, but still have an open circuit in them. I would test them with a meter or test light. I have rarely seen a fuse link wire blow.
Old Feb 21, 2006 | 10:37 PM
nokeman's Avatar
Nope I sure didnt use a meter or a light. Maybe I should just replace them all. I couldnt imagine doing what I did would cause any "serious" damage. But then again, all this came about on a simple HU install.
Old Feb 22, 2006 | 12:21 AM
frisky2101's Avatar
so you where installing a new head unit (stereo?) and you had wires touch and spark... just wondering why you didn't disconnect the battery first? anyways, I am wondering if all the things are related seems to be alot of stuff got messed up for just two wires touching
Old Feb 22, 2006 | 02:54 AM
ultraz's Avatar
if its your dimmer, it could be semi-serious......... Check to see if any dash light functions work with your dimmer switch on the left side of steering wheel,......... who knows, could be as simple as a blown dimmer switch.
Old Feb 22, 2006 | 08:10 AM
nokeman's Avatar
nope the dimmer swith works. i have all backround lighting to my instument panel.
Old Feb 22, 2006 | 10:47 AM
nokeman's Avatar
I got everything working now. I just replaced all the fuses and there must have been one blown even though they all looked good. Thanks for all the help guys!!
Justin
Old Feb 22, 2006 | 01:01 PM
rotwiler's Avatar
Glad to see it all worked out.
Old Feb 22, 2006 | 02:12 PM
Good deal. I figured it was a fuse.
