Can i still use the Stock Headunit??
Old Feb 23, 2006 | 06:57 PM
BlackBirdWs6Zzz's Avatar
Default Can i still use the Stock Headunit??
I have a box and subs and am getting an amp and i was wondering if i would be able to wiret his to my stock headunit ( i love it cuz it has an actual equalizer) Any help would be great. Not looking to spend money on a head unit at the moment.
Old Feb 23, 2006 | 07:36 PM
HiTechGent's Avatar
Yes, as long as you either get an amplifier with high level (speaker) inputs or use line-level converters.
Old Feb 23, 2006 | 11:01 PM
what are those.....? sorry. I'm a little slow when it comes to ELECTrical stuff
Old Feb 24, 2006 | 08:08 AM
HiTechGent's Avatar
Head units typically have a small built in amplifier to enable them to drive speakers directly. Many aftermarket HU's give you low-level outputs that do not go thru this amplifier stage, called pre-amp outputs. These are only used if you have a seperate amplifier to drive your speakers and are typically routed thru RCA cables.
Some amplifiers (not many) only have low level RCA inputs. This requires the use of line level converters to take the speaker outputs from your head unit and convert them to low level RCA outputs to send to your amplifier.
Old Feb 24, 2006 | 10:22 AM
Which would you prefer for me to get? Or do i need to do both?
Old Feb 24, 2006 | 03:57 PM
ded71's Avatar
To make it easy I think you should buy an amp that has high level inputs. Then you can just wire it to the stock H/U.
Old Feb 24, 2006 | 05:04 PM
I just bought a 600 Watt Sony Xplode amp. It should be coming in the mail soon. Will this work? Does it have High level inputs?
Old Feb 24, 2006 | 10:20 PM
ded71's Avatar
You would have to check the manufacturers website, I'm not sure. By the way while lurking this board I have heard many unkind things said about sony car audio equipment. Never had any myself. Before you buy expensive things it is a good idea to research the forum, there is tons of information available to you.
Old Feb 25, 2006 | 08:58 AM
I have owned quite a bit of sony already and don't have any complaints as of now. Just movin on up. I'll check the sight. THANKS!
