Looking for a little more bass
i have heard two elemental design 6.5" woofers in a toyota truck and they sounded like 10"s or 12"s... they were stunning! even the 6.5" woofer's cones could travel like 4-5" up and down, its nuts...
Matt
Matt
Single 2 - or - Single 4
250/500 WRms
Specifications
Qts: .29
Qes: .32
Qms: 2.7
Fs: 25.5 Hz
Re: 3.5
Vas: 46.7 L
Mms: 110 g
Bl: 15.1 T*m
SPL: 86.7 dB
Sd: 350 cm^2
Xmax: 9.3 mm
Voice Coil: 62.5 mm
Magnet Width: 2.700"
Cutout Diameter: 9.125"
Mounting Depth: 3.000"
Weight: 8 lb
Total Height: 3.400"
Displacement: .03 ft^3
Outside Diameter: 10.250"
Application Outline
Spec
SQ10 Subwoofer
Sealed Enclosure
Yes
Vented Enclosure
Yes
Infinite Baffle
Yes
Box Size Suggestions Outline
Spec
SQ10 Subwoofer
Sealed ( small )
0.3cF
Sealed ( ideal )
0.5cF
Sealed ( large )
0.6cF
Vented ( ideal )
1.0cF Tuned to 30Hz
Vented ( DDLoud)
1.0cF Tuned to 35Hz
