Replacement Headunit & Sub-install question
Old Feb 27, 2006 | 12:50 AM
99SSHawaii's Avatar
Default Replacement Headunit & Sub-install question
Hi, I just recently had a Alpine CDE 9845 deck installed along with a kicker 400.1 amp hooked up to two JL 10w0's in a sealed box. I'm not how sure the system was installed, but the speakers in my sail panel are no longer getting a feed (Is this normal when adding a sub to the monsoon system), and is there a way to make these speakers functional again?
Also, I just bought this car, and the front speakers sound really, really weak.. I'm thinking due to using 4ohm speakers (previous owner). Also, would there be a way to bypass the monsoon amp to feed the front two from the deck itself thereby allowing the 4 ohm feed?
If not, aside from the alpine speakers in the sticky, what's a good alternative for a front set up. Coaxials?
Also, was the Alpine CDE 9845 a good choice for a headunit?
Old Feb 27, 2006 | 08:42 AM
Lubricant's Avatar
As far as the sail's not working, take the speakers out and check the connections..
If its the trunk panels, there are 2 wires that go to each side..
It is not normal for that to be cut.
Old Feb 28, 2006 | 01:10 AM
rotwiler's Avatar
Infinity 62.7i's are 2ohm like the stock speakers and fit perfect in the front doors of the Camaro, they even have seperate inputs for the monsoon to push the woofer and tweeter input(tweeter runs off the headunit). I replaced mine in the doors and also added the same speakers to the sailpanel and very happy with the sound now. I disconnected the 4inch rear speakers and extended the wire to run the tweeters on the 62.7i in the sailpanel.
Old Feb 28, 2006 | 03:06 AM
99SSHawaii's Avatar
so, I should check the connection at the speakers? or should I check them at the amp too? Anyone lese have that problem?
