Where to ground HU?
Old Mar 1, 2006 | 03:36 PM
FSUNole17's Avatar
Default Where to ground HU?
i believe my noise is coming from the HU ground, where should i ground it? its currently ground to the metal in near the shifter console, thanks!
Old Mar 1, 2006 | 04:01 PM
rotwiler's Avatar
The stock HU ground wire is what I used. When I connected the wire harness to my Kenwood it was just plug and play.
Old Mar 1, 2006 | 06:18 PM
FSUNole17's Avatar
i heard that this wasnt a good place and that it was a crappy ground
Old Mar 1, 2006 | 08:20 PM
seawolf18's Avatar
I used the factory ground on my harness and have no noise. The best ground would be to bare metal (No paint), and as short as possible. I dont know where under the dash your going to find that??
Old Mar 1, 2006 | 09:03 PM
Phoenix 5.7's Avatar
mine is grounded to a bolt for the shifter. no problems here. bare metal is crutial
Old Mar 1, 2006 | 09:25 PM
rotwiler's Avatar
I could see grounding a aftermarket HU in a different location if you were using a really high power HU, like the Panasonic digital one that require the positive to go directly to the battery and are putting out around 35+ watts rms, but for a HU like the Kenwood I have with 22 watts rms it works perfect.
Old Mar 2, 2006 | 12:42 AM
2MuchRiceMakesMeSick's Avatar
In show cars and my own cars I always run a seperate ground wire to bare(scratched metal), which is over kill I know. I havent heard any problems with the factory ground.
