firewall question
Old Mar 1, 2006 | 11:36 PM
916marine's Avatar
Default firewall question
I'm trying to run a power wire from my fuse box to my amp in my 98Z. I want to run it on the driver side. Does anybody know where there's space in the firewall to run the wire from the fuse to the amp in the back of the car?
Old Mar 2, 2006 | 02:32 AM
Blacker's Avatar
If you run it down the driver side, you will have drill a hole for the wire. The best thing to do is run it down the passenger side where there is a hole already. Run the power wire directly from the battery to the amp. If you run the power wire from the fuse block, the wire being fed to the fuse block is 8 gauge. I can be a PITA to drill a hole. I had to drill a hole for my line-lock and LC-1.
