electronic help
Old Mar 2, 2006 | 12:12 AM
pontiacfireTAWS6's Avatar
Default electronic help
I have removed multiple things in my car. One thing in particular as an example is windshield wiper resevior. The electronics that go it, Can I cut wire excess or will that create problems? I have lots of wire excess I would like to get rid of.. any answers would be appreciated.
Old Mar 2, 2006 | 12:35 AM
2MuchRiceMakesMeSick's Avatar
if it shorts out it could become a problem, possibly even dangerous. If your serious about weight reduction, why not take the entire wire out?
Old Mar 2, 2006 | 02:14 AM
Id like to take the whole wire out.. It seems like there is no easy way. Under the looms and taped up with tons of other wires..
Old Mar 2, 2006 | 09:55 AM
618HAWK's Avatar
Cut it where you want and terminate-cap the ends to keep things in check IE shorts grounds ect. For the washer resv. with the level connector off you might have a low level light on if just disconnected. So you might have to splice those two together, not sure just a thought.
