Installing amp w/ stock h/u.......two 8's or one 10
I got an Orion Cobalt 702 for $20 from a buddy and I want to install it with my factory h/u. I'm not sure if Orion is a decent brand at all, but I've read that they were ok. Does anyone know the specs on these amps? I don't have a Monsoon system. Are all the cars equipeed with the "subs" in the back panels? I don't want a competition system or anything. I just started looking at pumping up the low end a bit. I like a nice tight response. Any tips on how I should hook this up? And...........do you you recommend two 8's or a single 10. I'm not looking at spending alot of jack (as you can tell) I've got alot of stereo install friends, but I have to get some input from people who have f-body's. If anybody would give me their $.02, I would appreciate all input. Thanks!!
Joe
Joe
I believe the non-Monsoon equipped cars had full-range speakers driven from the stock head unit in both doors and sails, with no speakers in the rear hatch area.
If it's bass your looking for, I'd think one 10" beats 2x 8".
That's wierd, because I have door, sails and hatch speakers. The sails are low end only. If it were a monsoon, I wouldv'e seen an amp somewhere and it should say something special on the h/u. I did buy this car used and haven't done anything stereo-wise at all to it. Did they have a special RPO code for a Monsoon system?
i got that plug in adapter from Pac that adds rcas and a remote turn on wire with no cutting,hooked up to a alpine 350 some **** mono amp and a 10w3, it jams...btw that Orion is very decent been around since the 80s and the old **** was better from them
Jeremy
Jeremy
Joe
Joe
Get a single 10" and either a Subthump, MTX, or JL box. Or you can buy a Sub and Box from MTX or JL. The 10 sounds like it'll fit your needs perfectly.
As for the wiring, I'm not sure off hand. I don't have my car around to take a look. I have the same set-up as yours.
