how hard is it to add an additional amp?
As for the remote cable: Most HU can flow enough current to support 3-4 amps for turn on. I'd check the specs to be sure, but this is usually the case on almost everything I've ever worked on except a bad HU. So, you should be able to just jumper off the other Amp's remote and use that to turn on the second amp.
