how do you pull the head unit out
Old Mar 12, 2006 | 05:58 PM
smokinHawk's Avatar
Default how do you pull the head unit out
They should add this to the sticky.
but can some one tell me the best to remove the head unit?
i tried searching an nothing came up.
do i need to remove the whole dash or is it simplier?
Old Mar 12, 2006 | 06:05 PM
jsnone1's Avatar
just pull th ebezel, it pops right off
Old Mar 12, 2006 | 06:07 PM
jsnone1's Avatar
https://ls1tech.com/forums/wiring-stereo-electronics/351228-how-remove-bezel-front-radio.html
even has a video for ya!!!
Old Mar 12, 2006 | 06:08 PM
jsnone1's Avatar
direct link to video http://users.rcn.com/my57chevy/RadioBezel.wmv
Old Mar 12, 2006 | 06:20 PM
sdm1234's Avatar
What about the rest of the unit?
Old Mar 12, 2006 | 06:30 PM
smokinHawk's Avatar
ya, i just found out how easy it is.
i just got done changing it and now see all the replies.
thanks guys
Old Mar 12, 2006 | 06:33 PM
umrjmac's Avatar
There are a couple of small bolts (one per side of the HU)...not sure on size... that you take out. Then you can pull the HU forward. There will be 2 or 3 connectors that you will have to pull loose on the back. 3 if you have a cd changer.
The first is the antenna wire...mine was a bit of a bitch to get out, but it pulls straight out.
The long narrow connector is the cd changer wiring harness, there is a clip thing on the top that you push down on (on the back of the connector) to pop the tip of it up so that it will come free. If you have ever pulled the main power connection on a PC motherboard loose, its the same style of thing.
The last one should be 2 pins tall and 1.5 or 2 inches wide. This wiring harness has power, dimmer control, power antenna control, speaker connections, etc in it. It has the same style molded-in clip as the other connector. push on the end of it and pull straight out.
Old Mar 12, 2006 | 11:37 PM
VIP1's Avatar
Copy & Paste Moderator
Hey, thats my video.
I'm glad people are finding it helpful.
3 bolts, two on one side, one on the other.
I think they are 7 or 9 mm.
Old Mar 13, 2006 | 07:53 AM
WhiteBird00's Avatar
Ungrounded Moderator
They are 5mm bolts with 7mm head (use a 7mm socket or wrench).
Old Mar 14, 2006 | 06:13 AM
Richiec77's Avatar
Yeah. This is worth being stickied. I'll work on adding it to the FAQ.
DONE
VIP1 Thank you for the Video. Makes explaining it Simple.
Old Mar 14, 2006 | 07:22 PM
VIP1's Avatar
You're Welcome.
