Fog Lamp Problem
Old Mar 26, 2006 | 04:46 PM
jade93lt1's Avatar
Default Fog Lamp Problem
so here is my problem: I have a 93 z28 and the other night for some reason i decided to turn on the high beams......so okay fine right................well later on that night my buddies pulls up like your fog lights are out......okay.....so when the high beams are turned on the fog lamps automatically shut off in every camaro (atleast from the factory)......so im geting power to the illumination on the actuall fog lamp switch but no power to the fog lamps. (so it very well could be the switch but its definatly between the switch and the light asslembly(allready tested also changed relay for fog lamps and actuall bulns)) SO my question is does anyone know if there is some kind of realay that turns the fog lamps off when the high beams go on????????? and if so could some one give me clue to figure out where it is located at????Id like to see if ther eis something like that before i go replacing the switch!!!!!and if anyone has one let me know!!!!!!
Old Mar 26, 2006 | 07:09 PM
WhiteBird00's Avatar
Ungrounded Moderator
No, there is no relay that shuts off the fog lights when the high beams are on. The fog light relay coil grounds through the high beam circuit. When the high beams are on there is 12V+ on both sides of the relay coil so the relay doesn't trip. Use your tester to make sure you have ground on the light green wire at the relay when the high beams are off and power when they're on.
