HUMount
Old Apr 14, 2006 | 01:33 AM
Duffster's Avatar
Soon came today while I was out of town. . .
I'll have pictures of it before, during and after
installation on the board tomorrow evening
Shouldn't take more than 10 minutes I figure. . .
Duff
Old Apr 14, 2006 | 12:38 PM
Duffster's Avatar
Took me about 25-30 minutes (had to fabricate/modify both my current head unit mount and the new HUMount to fit properly. When Photobucket comes back up shortly, I'll post up the install procedure. . .
Other than bleeding (cut myself slightly w/SURGICAL BLADE on my drill) the intall was cake! Got about 15 shots for ya'll.
Old Apr 14, 2006 | 07:52 PM
Duffster's Avatar
Old Apr 14, 2006 | 09:07 PM
LS1Zedder's Avatar
Why did you cut it up like that man?
Old Apr 14, 2006 | 10:21 PM
Duffster's Avatar
With my aftermarket mounting bracket, and the HUMount unit, they wouldn't fit flush without modifying/cutting them...
If you notice about pictures 12 & 13, the top of the mounting bracket and the bottom of the HUMount are cut out. . so they fit flush together...
If you get the chance to order one, do it! It's very easy to install (even if you need mods) and just has a nice-factor to it that the factory could have done easily. I'm sure Mark at HUMount doesn't mind GM didn't do this They have slightly changed the process when the HUMount initially came out. They did the lights for me instead of me needing to do anything (based on the instructions on their web page).
Check them out at http://maptechenterprises.netfirms.c...a826db36eb457b
(Might have to copy/paste into address bar)
Duff
Old Apr 16, 2006 | 12:14 PM
LETHL_SS's Avatar
Looks good!
Old Apr 16, 2006 | 02:31 PM
ezrollin's Avatar
i have one and love it
Old Apr 22, 2006 | 04:39 PM
Duffster's Avatar
No one noticed the 3 foglight switches?
Old Apr 26, 2006 | 05:52 PM
Fratsit's Avatar
Do tell........
Old Apr 26, 2006 | 07:32 PM
Duffster's Avatar
2nd fog light switch for cutout and 3rd for neon lights in the tail panel (with CAMARO cutout)
2nd in use, 3rd in progress. . .
Old Apr 28, 2006 | 11:57 AM
Fratsit's Avatar
Nice... I did not realize your tail panel lit up.
Good work, my friend.
Frat
Old Apr 28, 2006 | 03:02 PM
  #32
FH212's Avatar
I just ordered the one for my Firehawk right now!!! Cant wait till its gets here to put it in!
Old Apr 28, 2006 | 03:16 PM
  #33
Duffster's Avatar
barring the need for modification, goes in easy! the site tells ya which lead to connect where to get dimmer to work also.
Old Jul 26, 2006 | 09:54 PM
  #34
Duffster's Avatar
Change completed. . .until later
To:
Old Jul 26, 2006 | 10:11 PM
  #35
ezrollin's Avatar
cool switches, they look stock and professional, rather than a cheap wal-mart switch
Old Jul 26, 2006 | 11:03 PM
  #36
Duffster's Avatar
They're genuine foglight switches and I got the harnesses w/them so I can adapt them as necessary. I had the 4th switch in use for my line lock, but I changed it last week so the line lock is now on my shifter:
I've painted my rear panel and need to fill in the CAMARO letters w/clear epoxy and then worry about the lighting situation behind them... TIGHT space in there. . .for now!
