Fog Lights
Old Apr 5, 2006 | 08:17 PM
dom11's Avatar
Default Fog Lights
anyone know how to replace the bulbs on a trans am?
Old Apr 6, 2006 | 02:09 PM
ScrapMaker's Avatar
don't you just reach in the holes below the turn signals? if not, then you will have to start removing trim panels... which sucks. you had to pull off several panels on 3rdgen firebirds.
Old Apr 6, 2006 | 02:46 PM
VIP1's Avatar
Copy & Paste Moderator
I dont know about the Trans Am, but its easy on the Formula.
Look under the nose. You'll see a plastic flap under the nose in-front of each wheel secured with 1 or 2 screws. Undo the screws. Pull down the flap and reach in for the back of the bulb. Twist-n-pull to remove the bulb. When putting in new bulbs, do not touch the glass of the bulb. Halogen bulbs (and HID too) burn very hot. The oils from your hand will be left on the bulb and can cause premature failure.
