MOnsoon Question
Old Apr 6, 2006 | 01:49 PM
LO3Formula's Avatar
Default MOnsoon Question
I tried a search but could not find what I needed to know. I took the Monsoon unit out of my dads 02 SS and It has a barcode and a 4 digit number on the face (6067) and I'm going to throw it in my third gen. My question is are the numbers 6067 the unlock code or do I need to follow the steps I found from the search to unlock it?
Thanx
Matt
Old Apr 6, 2006 | 02:36 PM
LO3Formula's Avatar
Please?! lol
Old Apr 6, 2006 | 02:42 PM
VIP1's Avatar
Copy & Paste Moderator
I dont know, but you might still need to follow the procedure to unlock it.
Old Apr 6, 2006 | 08:33 PM
todddchi's Avatar
If the radio is still brand new and that is the factory placard, then it is probably the code. Certainly keep it, and you'll find out if you need it when you power the radio on.
Once you get it working I'd recommend deleting the code. It can only be a pain in the **** later.
If you the radio is locked and that's not the code, there's a thread around somewhere about how to get around it.
Old Apr 7, 2006 | 09:45 AM
shouldaboughttheZ's Avatar
If the theft lock does come on then do this:
Theftloc Bypass
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed 2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 202107, press the “button” and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Update…
Originally posted by I_EAT_Z28
Try this. I found it on another forum.
The dealer quote listed on the thread does not work, but i was able to find one on the internet. The 5-digit code which did it for me was 06010. Before this a 2 must be entered for Pontiac, and an asterisk after, so when prompted after calling 1-800-537-5140, pontiac guys enter: 206010. The website where i got the dealer code is here: Google cache.
Old Apr 7, 2006 | 11:48 AM
LO3Formula's Avatar
Thanks guys I appreciate it!
