Question for a nub.
Old Apr 18, 2006 | 11:40 PM
LFNDUST's Avatar
Default Question for a nub.
I know this question has probably been asked a million times, but just for clarification can you use the stock amp with a aftermarket deck? and or can you use stock deck with after market amp, and if so do I have to run the the amp wires to the deck or can you run them off a speaker, and another question can you use after market speakers with the stock amp...
Old Apr 19, 2006 | 04:15 PM
ded71's Avatar
You can pretty much do all of the things you asked. The equipment you need will differ, depending which way you decide to go. If I were you I would go with a new H/U. The stock monsoon H/U is not a good way to start building a system. Some people like them for the stock look or are afraid of theft, but an aftermarket H/U will give you better sound quality, and more control to adjust things to your liking. A new head unit will install easily and be a good foundation for building the rest of your system.
If you decide to get one just make sure the unit has all the options you are looking for like 3 sets of RCAs out, built in crossovers, aux inputs, stuff like that. A unit with these features will be a bit more expensive up front, but down the road it will make your upgrades easier and you will be happier that you didn't screw yourself in the begining. Good luck.
