Road Noise
Old Apr 24, 2006 | 12:44 PM
shouldaboughttheZ's Avatar
How much weight does it actually add?
I have done my doors and most of the trunk on mine and the rolls were not that heavy.
Old Apr 24, 2006 | 12:55 PM
WhiteRhino's Avatar
I'm not sure exactly how much. I think the bulk packs were 40-50lbs each and the door kit was around 30lbs. Then agian I'm not sure. Not alot of people like to add around 100lbs to their car. They're usually trying to get rid of it.
Old Apr 26, 2006 | 01:35 PM
ohsofast's Avatar
how much of a difference is that. I mean does it muffle your exhaust as well as the road noise. Is it like family car quiet. Maybe if I did that my wife would stop *ithchin about my car.
Old Apr 27, 2006 | 04:02 PM
WhiteRhino's Avatar
With headers, no cats and a Hooker catback and the cutout closed it's pretty quiet. Like I said though, my whole entire car is done. Including some outside panels. It also makes a big difference on how your stereo sounds. I had to go through and readjust everything. I also have a huge stereo set-up in my car.
Old Apr 28, 2006 | 02:27 PM
ohsofast's Avatar
I am highly interested in doing this, so you put it on the doors, floor board, trunk, and rear quarter panels. Also were is the best/cheapest place to get it. Went to the web site little bit higher than you stated
Old Apr 28, 2006 | 02:52 PM
WhiteRhino's Avatar
I also did outside in between the tail lights and body, the the headliner and the tranny tunnel under the car when I had my tranny out. I dont know if I can post where I got it from due to them not being sponsers so I'll pm it to you. I believe it was free shipping as well.
Old May 1, 2006 | 05:42 PM
ZDOG's Avatar
add true duals with dumps. bye bye road noise!
Old May 3, 2006 | 08:57 AM
JasonWW's Avatar
WhiteRhino, can you send me a PM on what you used and where you got it?
I need to add some to the back half of my car. My 3.73's make a little noise so the front, top and rear sheetmetal around the axle needs it the most in my case. Then we'll see what the next loudest source of noise is.
I've already done the doors. They should be the first thing that everyone does. Do the whole inner door panel and if you have extra, add it to the middle of the outer door panel. Not only will it reduce outside noise, but it will make your door speakers sound louder and better.
Lot of good info here:
http://www.sounddeadenershowdown.com/
