HVAC and Cluster LED problem
Old Apr 21, 2006 | 07:01 PM
98z2006's Avatar
Default HVAC and Cluster LED problem
I replaced my HVAC and cluster lights with LED's now none of them work. Belive problem happened when i was pulling out broken bulbs in HVAC but no blown fuses. Also no power to yellow and grey wire at light. I multi metered all the way under driverside dash with no sucess. weird thing i have blinkers and warning lights but no speed, tach, oil, etc. Any help for a newb appreciated.
Old May 2, 2006 | 10:44 PM
emj2006's Avatar
Was your battery disconnected when u did this? Have you tried them with the original lights installed instead of the new led ones?
Old May 3, 2006 | 10:00 AM
98z2006's Avatar
Yes i did, I have fixed the problem but thanks for the help. I couldn't figure it out untill i blew some fuses and went and bought a kit with a fuse puller/tester in it and a fuse with no signs of being blown was blown. weird but it happenned!!!! so i swapped out the fuse and walllla!!! green leds.
